NetApp Knowledge Base
ONTAP cluster running ONTAP 9.16.1 release experiences System Manager ONTAP update image validation failure
1,690
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ANDU (Automated Non-Disruptive Upgrade)
  • ONTAP 9.16.1
  • System Manager
Issue
When attempting to upgrade a ONTAP cluster running 9.16.1, after adding a ONTAP upgrade image via System Manager and subsequently attempt to Validate the package fails with the following message in System Manager:
On a 2 node cluster.
Validation couldn't be completed due to errors. Fix the errors, and validate again.
Pre-update check    Status      Message
ScriptExecution        x        Internal error. Initialization failed
  • Subsequent command line output of cluster image show-update-progress command shows the following output:
::> cluster image show-update-progress
                                             Estimated         Elapsed
Update Phase         Status                   Duration        Duration
Pre-update checks    failed                   00:10:00        00:00:00
Details:
Pre-update Check     Status            Error-Action
ScriptExecution      Error             Error: Internal error. Initialization
                                       failed
                                       Action: Verify that all nodes are
                                       healthy using the "cluster show"
                                       command, then try the command again
Overall Status       Error             Error
2 entries were displayed.
  • The output of the cluster image show-update-log advanced privilege level command also shows a failure in the "package-management" phase "synch-image" transaction:
::> set advanced
::*> cluster image show-update-log
                           Trans
Phase         Transaction  Id    Component Id      Time Stamp  Status
package-      process-     1     cluster1-01       3/26/2025   completed
management    package                              13:03:22
package-      synch-image  2     cluster1-02       3/26/2025   failed
management                                         13:03:22
validation    initialize   3     MUM               3/26/2025   failed
                                                   13:05:01
  Details: Error: Internal error. Initialization failed, Action: Verify that
           all nodes are healthy using the "cluster show" command, then try
           the command again.
validation    mount-image  4     cluster1-01       3/26/2025   completed
                                                   13:05:01
validation    mount-image  5     cluster1-02       3/26/2025   completed
                                                   13:05:01
validation    run-scripts  6     cluster1-01       3/26/2025   completed
                                                   13:05:01
validation    run-scripts  7     cluster1-02       3/26/2025   failed
                                                   13:05:01
           the command again.
validation    complete-    8     MUM               3/26/2025   completed
              validation                           13:05:01
8 entries were displayed.
On a cluster with more than 2 nodes:
MountPackage        Error       Error: Failed to mount the package
                                             Estimated         Elapsed
Details:
                                       Action: Run the "cluster image
                                       package show-repository" command to
                                       check if the package version is
                                       correct and available
::> set advanced
                           Trans
package-      synch-image  2     cluster1-03       3/26/2025   completed
management                                         13:03:22
                                                   13:05:01
  Details: Error: Failed to mount the package, Action: Run the "cluster image
           package show-repository" command to check if the package version is
           correct and available.
                                                   13:05:01
                                                   13:05:01
validation    mount-image  6     cluster1-03       3/26/2025   completed
                                                   13:05:01
validation    mount-image  7     cluster1-04       3/26/2025   failed
                                                   13:05:01
validation    mount-image  8     cluster1-05       3/26/2025   completed
                                                   13:05:01
validation    mount-image  9     cluster1-06       3/26/2025   failed
                                                   13:05:01
validation    complete-   10     MUM               3/26/2025   completed
              validation                           13:05:01
  • The cluster is healthy with no alerts:
::> cluster show
::> system health alert show
New to NetApp?
