NetApp Knowledge Base
ONTAP System Manager web interface is unresponsive while CLI remains available due to degraded RAID
298
Visibility:
Votes:
0
Category:
not set
Specialty:
not set
Last Updated:
Applies to
  • ONTAP 9 (all currently supported releases)
  • ONTAP System Manager (OSM) — browser-based cluster management UI
  • FAS / AFF / ASA platforms with degraded aggregates or RAID groups
Issue
ONTAP System Manager (OSM) web interface is intermittently or persistently unresponsive on the cluster-management LIF, while CLI access via SSH and Service Processor Infrastructure (SPI) continues to work normally.
Observed symptoms:
  • The browser stays on the loading spinner for a long time and never renders the dashboard, OR the dashboard appears briefly and then the session is logged out and returns to the login page.
  • Navigating between System Manager menus (Storage, Network, Events, etc.) returns to the login screen or hangs.
  • Browser developer tools show pending requests against the cluster-management LIF that are never answered (no HTTP response, eventually time out).
  • Accessing systemshell logs from System Manager or CLI is unusually slow and frequently times out.
  • The same behavior is reproduced from multiple browsers, including a private/InPrivate window, on multiple clients.
Steps that do not resolve the issue (because they do not address the underlying load on the web tier):
  • Moving the cluster-management LIF to a different node or port.
  • Connecting to a node-management LIF instead of the cluster-management LIF.
  • Restarting the web services with system services web modify -external true followed by re-enabling, or restarting the related daemons.
  • Regenerating or replacing the cluster, node, or web SSL certificates.
  • Performing a controlled takeover/giveback (TO/GB) or rolling reboot of the nodes.
New to NetApp?
