NetApp Knowledge Base
ONTAP System Manager 9.11.1+ shows "ERR_SSL_KEY_USAGE_INCOMPATIBLE" due to unsupported cipher suite
6,067
Visibility:
Votes:
0
Category:
ontap-system-manager
Specialty:
om
Last Updated:
Applies to
  • ONTAP System Manager 9.11.1 or later
  • Supported cipher suites
  • Certificates created pre ONTAP 9.12.1
Issue
  • ONTAP System Manager shows "ERR_SSL_KEY_USAGE_INCOMPATIBLE" in Chrome after upgrading to 9.11.1P5 or later
  • Error is seen while using a CA signed certificate
  • Firefox allows ONTAP System Manager access but with a warning as SEC_ERROR_UNKNOWN_ISSUER
  • While checking the security info on Firefox, its seen that the cipher suite in use is TLS_AES_128_GCM_SHA256
ONTAP System Manager 9.11.1 shows "ERR_SSL_KEY_USAGE_INCOMPATIBLE" due to unsupported cipher suite
New to NetApp?
