NetApp Knowledge Base
Is it possible to export  volume file system analytics data in ONTAP System Manager?
27
Visibility:
Votes:
0
Category:
ontap-system-manager
Specialty:
OM
Last Updated:
Applies to
  • ONTAP System Manager(OSM)
  • Volume File system Analytics
Answer
It is possible to get the volume file system analytics data from OSM via API calls/using curl:
curl -X GET "https://<hostname> /api/storage/volumes/<volumeUUID>/files/%2F?return_metadata=false&type=directory&fields=analytics&return_timeout=120" -H  "accept: application/json" -H  "authorization: <Cluster login authorization>"
Additional Information
additionalInformation_text
