NetApp Knowledge Base
Nominal temperature exceeded alert on E-Series (E4024) due to ambient sensor fault
38
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
  • NetApp E-Series E4024
  • All hardware running a similar E-Series enclosure/midplane architecture
Issue
  • The following alerts are reported on the E-Series system:
    • Failure Entry 1: NOMINAL_TEMP_EXCEEDED-Recovery Failure Type Code: 7
      Component reporting problem: Thermal sensor ambient
      Status: Nominal temperature exceeded
    • Failure Entry 2: WB_CACHING_FORCIBLY_DISABLED-Recovery Failure Type Code: 378
  • The environmental temperature at the installation site is confirmed to be normal (approx. 20°C).
  • Other temperature sensors report normal values.
  • Example log output (from AutoSupport > STATE-CAPTURE-DATAssmShowSubTree):
 [TempSensor]
Status: Non-Critical
ComponentLabel: ambient
Temperature(C): 4
Warning?: Yes
Failed?: No
RelativeParentLocations: Enclosure(1)
  • The issue persists after the controllers' reboot.
New to NetApp?
