NetApp Knowledge Base
E-Series intermittent no power input on power supply
97
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
NetApp E-Series
Issue
SANtricity reports:  Failure Entry 1: SUPPORT_CRU_NOINPUT-Recovery Failure Type Code: 97 intermittently
Major Event Log reports:
Sequence number: 4568
Event type: 283B
Event category: Internal
Priority: Critical
Event needs attention: true
Event send alert: true
Event visibility: true
Description: Power supply failed
Event specific codes: 0/0/0
Component type: Power Supply
Component location: Shelf 99, Power Supply canister 2, Bay 1
Logged by: Controller in bay A
The power supply will return to normal and you will see it clear in the Recovery-Guru and Major Event Log.
Controller shelf component changed to optimal - Shelf 99, Power Supply canister 2, Bay 1
New to NetApp?
