NetApp Knowledge Base
E-Series IOM (ESM) has reported an exception event periodically however no Recovery Guru alert and no clear problem can be identified
34
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
NetApp E-Series
Issue
In the Major Event log the message IOM (ESM) has reported an exception event has occurred  keeps appearing at perodic times
Date/Time: xxx-xx-xx-xx
Sequence number: 3271
Event type: 2866
Event category: Failure
Priority: Warning
Event needs attention: true
Event send alert: true
Event visibility: true
Description: An IOM (ESM) has reported an exception event
Event specific codes: 0/0/0
Component type: Tray Component (ESM)
Component location: Tray 1, Slot B
Logged by: Controller in slot A
Checking the Recovery Guru there are no alerts, additionally the IOM's /ESM's are  both optimal:
         ESM card status:                 Optimal
         Firmware Version:                0120
         Configuration settings version:  Not Applicable
         Maximum data rate:               12 Gbps
         Current data rate:               12 Gbps
         Card communication:              OK
         Trunking supported:              No
         Product ID:                      DE224C
         Part number:                     111-04850+A3
         Serial number:                   032241003100
         Date of manufacture:             Not Available
         Product ID:                      DE224C
         Serial number:                   032241003354
New to NetApp?
