Write Latency issues observed in StorageGRID when utilized by FabricPool and backup applications
Applies to
- StorageGRID 11.8.0.7
- FabricPool
- NetBackup
Issue
Experiencing significant Write latency issues in StorageGRID environment, affecting both FabricPool and backup operations.
Troubleshooting Steps:
- Verify if the GRID system is configured with Erasure Coding.
- If Erasure Coding is enabled, determine the schema level
- Analyze the ingest behavior associated with the Erasure Coding configuration.
