NetApp Knowledge Base
Veeam Backup Fails to Connect to StorageGRID S3 Endpoint with Certificate Validation Errors
18
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
  • NetApp StorageGRID
  • Veeam Backup & Replication
  • Windows Server hosting Veeam Backup
  • Environments using SSL certificates issued by GeoTrust or DigiCert
Issue
When configuring Veeam Backup to connect to a StorageGRID S3 endpoint, certificate validation fails with errors such as:
Windows does not have enough information to verify this certificate.
Revocation Status Unknown — The revocation function was unable to check revocation for the certificate.
Failed to retrieve certificate from https://xx-xxx-xx.xxxx.xxxxx.xxx:10443
New to NetApp?
