Storage node in unknown state due to disk pool failure
Applies to
- SG5700
- SG6000
Issue
- Storage node reporting
Unknown
state in Grid Manager - SANtricity System Manger reporting the following:
DISK_POOL_RECONSTRUCTION_DRIVE_COUNT_BELOW_THRESHOLD-Recovery Failure Type Code: 424
SAS_PORT_FAILED-Recovery Failure Type Code: 113
UNKNOWN_COMPONENT_STATUS-Recovery Failure Type Code: 61
- Multiple entries of this with location to a specific drawer
- For example:
- For example:
WB_CACHING_FORCIBLY_DISABLED-Recovery Failure Type Code: 378
VOLUME_GROUP_INCOMPLETE-Recovery Failure Type Code: 201
- Should have
Shelf:
field matching the shelf of theUNKNOWN_COMPONENT_STATUS
location- For example:
Shelf: Controller/Drive shelf 99, Drawer 5
- For example:
- Should have
- Disk pool is in a
Failed
state- Click Storage > Pools & Volume Groups
