NetApp Knowledge Base
StorageGRID Replicated State Machine "RSM" stuck in starting state
931
Visibility:
Votes:
2
Category:
storagegrid-webscale
Specialty:
sgrid
Last Updated:
Applies to
NetApp StorageGRID 11.2 and later
Issue
Expansion was either completed or stuck in "upgrading" stage
  • Output of 'storagegrid-status' shows RSM in a starting state
  • File called 'expansion-started' exists within '/var/local/rsm' directory if the expansion was not yet finished
  • Example error in bycast-err.log:
    • rsm[11204]: [raft.go:135] CRITICAL: Failed to join cluster
  • servermanager.log:
    • rsm | RSM is not ready because there is no cluster or the cluster has no leader
New to NetApp?
