NetApp Knowledge Base
StorageGRID upgrade pre-check issue identified by the persistence list customization
584
Visibility:
Votes:
0
Category:
storagegrid-webscale
Specialty:
sgrid
Last Updated:
Applies to
StorageGRID 11.2 - 11.7
Issue
While performing an upgrade from an 11.2 - 11.7 StorageGRID firmware, the pre-check returns error message with persistence check:
It is not safe to proceed with the upgrade at this time.
The pre-check operation has detected conditions that must be addressed before upgrading. Resolve the issues listed below and click Start Upgrade or Run Pre-checks to retry. Contact Technical Support for assistance in resolving these issues, if necessary.
o    The list of persistence configuration files found on X.X.X.00026 did not match the expected list.
o    The following issues were identified by the Persistence list customizations pre-check:
o    The list of persistence configuration files found on X.X.X.00027 did not match the expected list.
o    The list of persistence configuration files found on X.X.X.00028 did not match the expected list.
o    The list of persistence configuration files found on X.X.X.00029 did not match the expected list.
o    The list of persistence configuration files found on X.X.X.00030 did not match the expected list.
o    Found unexpected content in custom.conf persistence configuration file on X.X.X.00031.
New to NetApp?
Scan to view the article on your device
