NetApp Knowledge Base
StorageGRID upgrade from 11.2.0.6 to 11.3.0 fails at final steps "ssh_exchange_Identification: connection reset by peer"
192
Visibility:
Votes:
0
Category:
storagegrid-webscale
Specialty:
sgrid
Last Updated:
Applies to
  • Platform: StorageGRID Webscale
  • Environment: Admin Nodes and Storage Nodes are all VMware
  • Version: 11.2.0.6 to 11.3.0
Issue
  • During StorageGRID upgrade from 11.2.0.6 to 11.3.0 fails at the final steps from the GUI/NMS with error "ssh_exchange_Identification: connection reset by peer".
[2020-07-17T01:16:36.985297 #17185]  INFO -- : Executing command `scp -o NumberOfPasswordPrompts=0 -o CheckHostIP=no -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no root@hostname:"/var/local/adc/bundles/BNDL/0x00000000/GfINF.BNDL.bin" "/tmp/GINF.BNDL.bin" 2>&1` on localhost
[2020-07-17T01:16:37.004547 #17185] ERROR -- : Error while running upgrade final steps.
[2020-07-17T01:16:37.004684 #17185] ERROR -- : Failed to execute scp command with '{:file=>"\"/var/local/adc/bundles/BNDL/0x00000000/GINF.BNDL.bin\"", :host=>"xadnsgstg201"}, {:file=>"\"/tmp/GINF.BNDL.bin\"", :host=>"localhost"}, {:secure=>false, :check=>false}' on localhost - 1, ssh_exchange_identification: read: Connection reset by peer (Bycast::StorageGRID::RetrieveBundle::Error)
  • All nodes in this GRID has upgraded to version 11.3.0, however it has stuck at this final steps that would not let the GRID finish its completion.
New to NetApp?
Scan to view the article on your device
