NetApp Knowledge Base
StorageGRID decommission paused at erasure coded data due to read only volume
343
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
NetApp StorageGRID
Issue
  • StorageGRID node decommission pauses at Decommissioning Erasure Coding Data.
  • After resuming erasure coding decommission, the job pauses again.
  • /var/local/log/bycast.log on EC Leader show following EC Job Manager exception:
Caught exception 'ENFORCE failed: 'SUCS' == jobResult.value()' when running job <job ID>: Storage Node Decommissioning
  • /var/local/log/bycast.log  or /var/local/log/bycast.log.x on Source node shows VCSCopy terminating (repeatedly):
VCPY: VCS not making progress
VCPY: Retry limit reached in VCS copy <VCS ID> to <Node ID>: Terminating VCSCopy
VCPY: Sending VCS copy response to process {<ID>} for VCS <VCS ID>, result: GERR.
  • /var/local/log/bycast.log or /var/local/log/bycast.log.x on Target node show volume read only while trying to copy chunks into the VCS:
WARNING: PUT <ID> - failed with 503: volume read only
VCS notification (EVFL) sent to service id ECLD on node <Node ID> for VCSId <VCS ID>
New to NetApp?
