Rubrik Archival Jobs to StorageGRID Fails with FingerprintValidationFailed due to a single node down
Applies to
- NetApp StorageGRID 11.x
- Rubrik backup solutions integrating with StorageGRID
- StorageGRID environments configured with single replicated copy ILM policy
Issue
Rubrik archival jobs targeting NetApp StorageGRID began failing with Internal error FingerprintValidationFailed.
Rubrik UI:
- StorageGRID reports "Unable to communicate to the Node".
var/local/log/servermanager.logof the affected Node has below entries : -2026-05-23 02:30:00 +0000 | ldr | ldr ended2026-05-23 02:30:38 +0000 | ldr | using jemalloc from /lib/x86_64-linux-gnu/libjemalloc.so.22026-05-23 02:30:38 +0000 | ldr | ldr starting2026-05-23 02:30:43 +0000 | ldr | ldr ended- Object metadata lookup revealed a missing patch file.
