NetApp Knowledge Base
Multipart upload fails with HTTP status code 400 with Error InvalidPart in StorageGRID
383
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
StorageGRID 11.7
Issue
  • Intermittent Multipart upload fails with HTTP status code 400 with Error InvalidPart:
(Service: Amazon S3; Status Code: 400; Error Code: InvalidPart; Request ID: <>; S3 Extended Request ID: null; Proxy: null), S3 Extended Request ID: null:InvalidPart: 's entity tag.
  • bycast.log indicates POST sent before all multipart parts are uploaded:
<NODE 1>
May 14 13:42:34 <NODENAME> ADE: |12028595 2245782683 S3RQ %CEA 2024-05-14T13:42:34.616685| NOTICE   1418 <> S3RQ: EVENT_PROCESS_CREATE - connection=<> method=PUT name=</<OBJECT_PATH>&partNumber=4> auth=<V4> clientIP=<IP_ADDRESS>
<NODE 2>
May 14 13:42:34 <NODENAME> ADE: |12098350 1413203066 S3RQ %CEA 2024-05-14T13:42:34.616484| NOTICE   1418 <> S3RQ: EVENT_PROCESS_CREATE - connection=<> method=PUT name=</<OBJECT_PATH>&partNumber=2> auth=<V4> clientIP=<IP_ADDRESS>
<NODE 3>
May 14 13:42:34 <NODENAME> ADE: |12452071 2213603800 S3RQ %CEA 2024-05-14T13:42:34.616426| NOTICE   1418 <> S3RQ: EVENT_PROCESS_CREATE - connection=<> method=PUT name=</<OBJECT_PATH>&partNumber=3> auth=<V4> clientIP=<IP_ADDRESS>
<NODE 4>
May 14 13:42:34 <NODENAME> ADE: |12431938 1455994768 S3RQ %CEA 2024-05-14T13:42:34.822377| NOTICE   1418 <> S3RQ: EVENT_PROCESS_CREATE - connection=<> method=POST name=</<OBJECT_PATH>> auth=<V4> clientIP=<IP_ADDRESS>
<NODE 5>
May 14 13:42:34 <NODENAME> ADE: |12431938 1455994768 S3RQ ^RDY 2024-05-14T13:42:34.845127| NOTICE   0103 859318ca07528527 S3RQ: S3 error response: RequestId=<>, TraceId=<>, Resource=/<OBJECT_PATH>, HTTP Method=POST, HTTP Status Code=400, X-Forwarded-For: '<>', ErrorMsg=InvalidPart, ErrorType=Client, CustomErrorMessage={None}, Details={None}
New to NetApp?
