NetApp Knowledge Base
Is it a fixed number for noncurrent versions retained in a versioned S3 bucket prior to StorageGRID v11.7?
20
Visibility:
Votes:
0
Category:
storagegrid-webscale
Specialty:
esg
Last Updated:
Applies to
Answer
  • What's new in StorageGRID 11.7 mentions that NewerNoncurrentVersions action can specify the number of noncurrent versions retained in a versioned S3 bucket.
  • But It does not mean the number of versions to retain is fixed for StorageGRID 11.60 or earlier.
  • Before v11.7, only the following method was supported for managing the rotation of versioned objects:
Bucket lifecycle: Use the NoncurrentVersionExpiration action in the bucket lifecycle configuration. When the number of NoncurrentDays specified is met, StorageGRID permanently removes all copies of noncurrent object versions. These object versions can't be recovered.
Additional Information
From StorageGRID StorageGRID 11.7
NewerNoncurrentVersions threshold for S3 buckets
The NewerNoncurrentVersions action in the bucket lifecycle configuration specifies the number of noncurrent versions retained in a versioned S3 bucket. This threshold overrides lifecycle rules provided by ILM. See How objects are deleted.
  • Bucket lifecycle: Use the NoncurrentVersionExpiration action in the bucket lifecycle configuration. When the number of NoncurrentDays specified is met, StorageGRID permanently removes all copies of noncurrent object versions. These object versions can't be recovered.
The NewerNoncurrentVersions action in the bucket lifecycle configuration specifies the number of noncurrent versions retained in a versioned S3 bucket. If there are more noncurrent versions than NewerNoncurrentVersions specifies, StorageGRID removes the older versions once the NoncurrentDays value has elapsed. The NewerNoncurrentVersions threshold overrides lifecycle rules provided by ILM, meaning that a noncurrent object with a version within the NewerNoncurrentVersions threshold is retained if ILM requests its deletion.
