How to check if an object has delete markers for StorageGRID
Applies to
Answer
To check for the existence of delete makers in a bucket against an object, you can run the following command via AWS CLI:
aws --profile --endpoint-url s3api list-object-versions --bucket --prefix --no-verify-ssl
If delete markers exist, the output will show a "DeleteMarkers" section as shown below:
"Versions": [
"ETag": "\"b072axxxxxc5096af6xxxxxx737dd87e\"",
"Size": 70685,
"StorageClass": "STANDARD",
"Key": "image.png",
"VersionId": "NTlEMUMwN0MtMDkwQS0xMUYxLTlERUMtQ0ZCQTAwQkU3NTE1",
"IsLatest": false,
"LastModified": "2026-02-13T18:32:28.643Z",
"Owner": {
"DisplayName": "deactivate EC",
"ID": "40430905654028310759"
"DeleteMarkers": [
"Owner": {
"Key": "image.png",
"VersionId": "QjgyMjJFRTAtMDkwQi0xMUYxLTg5MDYtRDA3MzAwQkQzNjlD",
"IsLatest": true,
"LastModified": "2026-02-13T18:42:16.373Z"
"RequestCharged": null,
"Prefix": ""
If no delete markers are found, the output will not show a "DeleteMarkers" section and "IsLatest" will be "true" as shown below:
"Versions": [
"ETag": "\"41xxxx407a01ddxxxxxx81309fbxxxx1-1\"",
"Size": 35487,
"Key": "GXD-XXX-1/NEW_DOCUMENT1/FILE-1.pdf",
"VersionId": "Njg3QTMzQzQtRTY1Ni0xMUYwLTlFNEUtMkFGRDAwQzJBQjRG",
"IsLatest": true,
"LastModified": "2025-12-31T14:38:44.352000+00:00",
"Owner": {
"DisplayName": "nve",
"ID": "51881xxxxx714256xxx2"
"Prefix": "GXD-XXX-1/NEW_DOCUMENT1/FILE-1.pdf"
