NetApp Knowledge Base
Does objects delete after object lock is expired on StorageGRID?
188
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
  • StorageGRID 11.8
  • Object lock enabled bucket
  • Retention set to X number of days
Answer
  • No, objects are NOT deleted when the retention period expired for the object lock set on the bucket.
  • Object lock on the objects are only removed based on the retention period.
  • Since the bucket is compliant, ILM rules cannot be set to delete the objects due to:
    • A compliant ILM rule requires the rule to have the retention period as FOREVER, which will not work in the case of deleting objects.
    • If ILM rule is created to retain objects for x days, the rule is NON-COMPLIANT and will not be in effect with the COMPLIANT bucket.
  • Use the bucket lifecycle policy to manage the automated deletion of the COMPLAINT object lock bucket.
Additional Information
Managing objects with S3 object lock
Example of a bucket lifecycle policy (for versioned buckets)
    "Rules": [
            "ID": "ExpireNonCurrentVersions",
            "Filter": {},
            "Status": "Enabled",
            "NoncurrentVersionExpiration": {
                "NoncurrentDays": 1
