NetApp Knowledge Base
Cassandra repair progress slow alert and frequent cassandra-reaper service restarts on StorageGRID 11.4
2,568
Visibility:
Votes:
1
Category:
storagegrid-webscale
Specialty:
sgrid
Last Updated:
Applies to
  • NetApp StorageGRID 11.4 (pre-11.4.0.3)
  • New StorageGRID deployment
  • NetApp StorageGRID environment upgraded from 11.3 (pre-11.3.0.11 hotfix)
Issue
  • After new deployment of StorageGRID 11.4 or upgrade from pre-11.3.0.11 release (example 11.3.0.10 or any other build of 11.3) to 11.4, users may receive the following alert in the StorageGRID GUI:
  • The Cassandra repair progress slow maybe a result of many issues including service unavailability and communication issues.
  • In order to confirm the issue matches this article, there are few additional signatures that can be checked:
  1. The Cassandra repair progress slow  alert has persisted over 2 days with effective repair percentage at 0%.
  2. The cassandra-reaper service responsible for the Cassandra repair operations is restarting frequently on various storage nodes.
This can be confirmed via the /var/local/log/servermanager.log file on the storage node(s):
| cassandra-reaper          | restart initiated
| cassandra-reaper          | cassandra-reaper ended
| reaper                    | starting reaper
  1. Cassandra reaper log under /var/local/log/cassandra-reaper.log or in lumberjack collection reaper.log contain an exception for failure to achieve consistency level QUORUM or EACH_QUORUM:
WARN [storagegrid:615635d0-342b-11eb-b6cc-4bacd6a2d5fe:615c9e91-342b-11eb-b6cc-4bacd6a2d5fe] 2020-12-08 18:57:38,140 i.c.s.SegmentRunner - Failed to connect to a coordinator node for segment 615c9e91-342b-11eb-b6cc-4bacd6a2d5fe
com.datastax.driver.core.exceptions.UnavailableException: Not enough replicas available for query at consistency EACH_QUORUM (2 required but only 0 alive)
  1. Cassandra reaper repair list from reaper_commands.txt in lumberjack collection of storage node(s) or by running this command spreaper --reaper-host=localhost --reaper-port=9403 status-cluster storagegrid in SSH session to a storage node, indicates that some or all keyspaces' repairs contain the following message for the last event:
      "creation_time": "2020-11-24T23:05:08Z",
      "current_time": "2020-12-08T18:59:39Z",
      "datacenters": [],
      "duration": "7 days 0 hours 2 minutes 13 seconds",
      "end_time": "2020-12-01T23:07:22Z",
      "estimated_time_of_arrival": null,
      "id": "7f8d00b0-2ea9-11eb-b76b-d7a5b22a5393",
      "incremental_repair": false,
      "intensity": 1.000,
      "keyspace_name": "storagegrid",
      "last_event": "Postponed a segment because no coordinator was reachable"
      "nodes": [],
      "owner": "auto-scheduling",
      "pause_time": null,
      "repair_parallelism": "PARALLEL",
      "repair_thread_count": 4,
      "repair_unit_id": "dc8dbfa0-17c7-11eb-b890-676ddd59fc8a",
      "segments_repaired": 0,
      "start_time": "2020-11-24T23:05:08Z",
      "state": "ABORTED",
      "creation_time": "2020-11-17T20:50:58Z",
      "current_time": "2020-12-08T18:59:40Z",
      "datacenters": [],
      "duration": "7 days 0 hours 0 minutes 32 seconds",
      "end_time": "2020-11-24T20:51:31Z",
      "id": "9882a450-2916-11eb-8180-07cae1e33f50",
      "intensity": 1.000,
      "keyspace_name": "reaper_db",
      "nodes": [],
      "pause_time": null,
      "repair_unit_id": "dc818aa0-17c7-11eb-b890-676ddd59fc8a",
      "start_time": "2020-11-17T20:50:59Z",
      "state": "ABORTED",
New to NetApp?
