Can not connect StorageGRID fabric pool during StorageGRID upgrade even by using multiple Gateway nodes
Applies to
- StorageGRID
- FabricPool
Issue
During StorageGRID upgrade, even by using multiple Gateway nodes, the following issues are still encountered.
- Windows server reports the below bad block error and hang within an iSCSI environment against ONTAP which is using the StorageGIRD as the cloud tier.
Example:
Error 2021/04/24 8:45:12 Disk 7 None The device, \Device\Harddisk7\DR7, has a bad block.
- ONTAP can not access the fabric pool and reports the below messages at the same time.
Example:
Sat Apr 24 08:45:08 JST [XX:OscHighPriThreadPool: object.store.unavailable:EMERGENCY]: Unable to connect to the object store "XXXX" from nodeXXXX.
