NetApp Knowledge Base
TLS handshake failure when connecting to StorageGRID object-store in Fabricpool
235
Visibility:
Votes:
0
Category:
storagegrid-webscale
Specialty:
sgrid
Last Updated:
Applies to
  • NetApp StorageGRID
  • ONTAP FAS Cluster
  • Fabricpool configuration
Issue
  • Newly installed FAS cluster cannot connect to StorageGRID FabricPool.
  • The GRID is configured using subnet (/32) and the Client Network is configured using subnet (/26).
  • The Intercluster LIFS can ping the StorageGRID tenant IP endpoint, but not able to connect.
  • Firewall is seeing packets received from FAS cluster but not from StorageGRID.
  • Error observed when creating object store with  -is-certificate-validation-enabled false:
    • Error: command failed: Cannot verify availability of the object store from node <cluster_name>.
      Reason: TLS: Handshake timed out.
  • Error observed when creating object store with -is-ssl-enabled false:
      Reason: Timeout: Operation "object_store_config_ksmf_iterator::create_imp()" took longer than 45 seconds to complete [from mgwd on node "cluster_name" (VSID: -1) to kernel at 100.xxx.xx.xxx].
  • Error running openssl command:
<cluster_name>::*> systemshell local sudo openssl s_client -connect <GRID_Endpoint>:<Port> -showcerts -CAfile /var/certificates/ssl/serverCA.pem
(system node systemshell)
CONNECTED(00000004)
write:errno=60
no peer certificate available
No client certificate CA names sent
SSL handshake has read 0 bytes and written 393 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
New to NetApp?
