StorageGRID reports appliance hardware components temperature alert
Applies to
- NetApp StorageGRID 11.9.0, 11.8.x
- NetApp SGF6112, SG6160
- NetApp SG110, SG1100
Issue
- Appliance(s) reports temperatures above 100°C in Support > Diagnostics > Appliance hardware component temperatures:
Node Component °CNode02-10 0000:30:02_0_0000:31:00_0 105Node02-10 0000:30:02_0_0000:31:00_1 105Node01-09 0000:30:02_0_0000:31:00_0 104Node01-09 0000:30:02_0_0000:31:00_1 104Node02-08 0000:b0:02_0_0000:b1:00_0 103Node02-08 0000:b0:02_0_0000:b1:00_1 103Node02-05 0000:30:02_0_0000:31:00_0 102Node02-05 0000:30:02_0_0000:31:00_1 102- The
ipmitool sensoroutput shows a low RPM for theFan_sys.
root@SG:~ # ipmitool sensor
Watchdog | 0x0 | discrete | 0x0080| na | na | na | na | na | na
Watchdog2 | 0x0 | discrete | 0x0080| na | na | na | na | na | na
Event Log | 0x0 | discrete | 0x0080| na | na | na | na | na | na
BroadcastSts | 0x0 | discrete | 0x0180| na | na | na | na | na | na
CPU0 | 0x0 | discrete | 0x8080| na | na | na | na | na | na
CPU1 | 0x0 | discrete | 0x8080| na | na | na | na | na | na
Fan_SYS0_0 | 8125.000 | RPM | ok | na | 500.000 | na | na | na | na
Fan_SYS0_1 | 6625.000 | RPM | ok | na | 500.000 | na | na | na | na
Fan_SYS1_0 | 8250.000 | RPM | ok | na | 500.000 | na | na | na | na
Fan_SYS1_1 | 6625.000 | RPM | ok | na | 500.000 | na | na | na | na
Fan_SYS2_0 | 8125.000 | RPM | ok | na | 500.000 | na | na | na | na
Fan_SYS2_1 | 6750.000 | RPM | ok | na | 500.000 | na | na | na | na
Fan_SYS3_0 | 8125.000 | RPM | ok | na | 500.000 | na | na | na | na
Fan_SYS3_1 | 6625.000 | RPM | ok | na | 500.000 | na | na | na | na
Fan_SYS4_0 | 8750.000 | RPM | ok | na | 500.000 | na | na | na | na
Fan_SYS4_1 | 7250.000 | RPM | ok | na | 500.000 | na | na | na | na
Fan_SYS5_0 | 8875.000 | RPM | ok | na | 500.000 | na | na | na | na
Fan_SYS5_1 | 7250.000 | RPM | ok | na | 500.000 | na | na | na | na
Fan_SYS6_0 | 8875.000 | RPM | ok | na | 500.000 | na | na | na | na
Fan_SYS6_1 | 7125.000 | RPM | ok | na | 500.000 | na | na | na | na
Fan_SYS7_0 | 8750.000 | RPM | ok | na | 500.000 | na | na | na | na
Fan_SYS7_1 | 7250.000 | RPM | ok | na | 500.000 | na | na | na | na
Temp_OCP_ASIC | na | degrees C | na | na | na | na | na | 100.000 | na
Airflow | 29.000 | CFM | ok | na | na | na | na | na | na
Chassis | 0x0 | discrete | 0x0080| na | na | na | na | na | na
OCP_Card | 0x0 | discrete | 0x0080| na | na | na | na | na | na
