High availability group highest priority node not active after StorageGRID upgrade
Applies to
StorageGRID 11.7
Issue
- After upgrading from StorageGRID 11.6 to 11.7, node with highest priority is not active in the high availability (HA) group.
- Under Node > (select node) > Hardware, one gateway node has high usage in CPU utilization and Memory usage than the other
- Under Support > Metrics > Node, CPU utilization and Memory usage decreased after upgrade to 11.7 on affected node.
