NetApp Knowledge Base
Why doesn't NODE_DOWN-MAJOR open a support ticket?
231
Visibility:
Votes:
0
Category:
storagegrid-webscale
Specialty:
sgrid
Last Updated:
Applies to
NetApp StorageGRID
Answer
  • By design, StorageGRID architecture allows one storage node to fail without any data loss or business impact.
  • When a single storage node fails, it will trigger the following alert: (NODE_DOWN-MAJOR) ERROR. This will create an alert in the GRID GUI, but will not open a support ticket unless another storage node goes down which will trigger the alert: (NODE_DOWN-CRITICAL) ERROR.
  • When two or more storage nodes go down there is a higher chance of business impact and data loss depending on the systems ILM rules and Erasure Coding scheme
Additional Information
Most (NODE_DOWN-MAJOR) ERROR are commonly associated with the following and tend to self-resolve in minutes:
If two or more storage nodes go down (NODE_DOWN-CRITICAL) ERROR will create an ASUP ticket
