NetApp Knowledge Base
What network does StorageGRID use to transmit AutoSupport messages?
1,472
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
NetApp StorageGRID
Answer
  • StorageGRID utilized standard network routing techniques that are automatically generated for each individual node based on the following:
    • If no client network (eth2) is configured on the node, the Grid network (eth0) is the default route.
    • If client network (eth2) is configured, then it becomes the default route.
  • AutoSupport messages are transmitted from StorageGRID admin node using the standard routes explained above.
Additional Information
  • StorageGRID includes support to configure custom network routes (Subnets) if certain traffic needs to be routed using a specific network interface (admin, grid or client)
  • To add a route for the admin network so it can be the default interface trasmitting AutoSupport messages, use the change-ip tool.
    • Under option 3, you can add support.netapp.com IP address (216.240.21.18/32) and/or proxy server (optional)
Welcome to the StorageGRID IP Change Tool.
Selected nodes: all
1:   SELECT NODES to edit
2:   EDIT IP/mask, gateway and MTU
3:   EDIT admin network subnet lists
4:   EDIT grid network subnet list
5:   SHOW changes
6:   SHOW full configuration, with changes highlighted
7:   VALIDATE changes
8:   SAVE changes, so you can resume later
9:   CLEAR all changes, to start fresh
10:  APPLY changes to the grid
0:   Exit
