NetApp Knowledge Base
StorageGRID reports CassandraRepairProgressSlow due to intermittent network issue
332
Visibility:
Votes:
0
Category:
storagegrid-webscale
Specialty:
sgrid
Last Updated:
Applies to
  • NetApp StorageGRID 11.7 and above
  • StorageGRID deployments with imbalance of nodes across sites.
Issue
  • StorageGRID UI reports CassandraRepairProgressSlow alert.
  • Support > Metrics> Cassandra Network Overview > Reaper Repair Percentage shows long periods of repair not running and starting again.
  • spreaperlist-runs output lists:
"creation_time": "2024-12-30T21:13:21Z",
   "current_time": "2025-01-16T17:10:12Z",
    "datacenters": [],
    "duration": "16 days 19hours 56 minutes 50 seconds",
    "end_time": null,
    "estimated_time_of_arrival":"2025-03-15T07:52:03Z",
    "id": "xxxxxxx-xxxxx-xxxxx-xxxx-13c2ca0716a2",
    "incremental_repair": false,
    "intensity": 1.0,
   "keyspace_name": "reaper_db",
   "last_event": "Postponed a segment because no coordinator was reachable",
    "nodes": [],
    "owner": "storagegrid",
    "pause_time": null,
    "repair_parallelism":"PARALLEL",
    "repair_thread_count": 4,
    "repair_unit_id":"XXXXX-ba4f-11eb-ba15-f975a0a43552",
    "segments_repaired": 3187,
   "start_time": "2024-12-30T21:13:22Z",
   "state": "RUNNING",
   "total_segments": 14096
  •  reaper.log (cassandra-x.x.x.x/reaper/reaper.log) from StorageGRID logs from a node at each site report:
    • Node at Site 1:
      • INFO[StorageGRID-name1] 2025-01-16 17:21:08,651 i.c.s.CassandraStorage -Retry for 100th time, rethrowing
        WARN[storagegrid:]2025-01-16 17:21:08,652 i.c.s.SegmentRunner - Failed to connect to a coordinator node for segment xxxxxxx-xxxxx-xxxxx-xxxx-13c2ca0716a2
        -com.datastax.driver.core.exceptions.WriteTimeoutException: Cassandra timeoutduring CAS write query at consistency SERIAL (4 replica were required but only3 acknowledged the write)
        INFO[storagegrid:]2025-01-16 17:21:08,850 i.c.s.RepairRunner - Postponed a segment because no coordinator was reachable
        INFO[storagegrid:]2025-01-16 17:21:08,851 i.c.s.SegmentRunner - Postponing segment xxxxxxx-xxxxx-xxxxx-xxxx-13c2ca0716a2
    • Node at Site 2:
      • WARN[storagegrid:]2025-01-16 17:22:28,901 i.c.s.SegmentRunner - Failed to connect to a coordinator node for segment xxxxxxx-xxxxx-xxxxx-xxxx-13c2ca0716a2
        com.datastax.driver.core.exceptions.WriteTimeoutException:Cassandra timeout during CAS write query at consistency SERIAL (4 replica were required but only 0 acknowledged the write)
        INFO[storagegrid:]2025-01-16 17:22:39,269 i.c.s.CassandraStorage - Trying to release lead on segment xxxxxxx-xxxxx-xxxxx-xxxx-13c2ca0716a2 for instance xxxxxxxx-xxxx-xxxx-xxxx-97819177c25f
        ERROR[storagegrid:]2025-01-16 17:22:39,269 i.c.s.CassandraStorage - Could not release lead on segment xxxxxxx-xxxxx-xxxxx-xxxx-13c2ca0716a2
New to NetApp?
