StorageGRID reports AutoSupport message failed to send to Additional Destination
Applies to
NetApp StorageGRID
Issue
- StorageGRID UI reports alert
AutoSupport message failed to send.
- Weekly, Event-Triggered, and User-Triggered AutoSupport are sending to NetApp Support as expected.
- Additional Destination shows
Failed
nms.login/var/local/logshow the following error to the additional destination configured:ERROR Connection to autosupport destination https://IP_Address:Port failed with error Connection reset by peer - SSL_connect
nms.login/var/local/logshows the following successful weekly ASUP message:INFO Successfully sent WEEKLY Asup to destination https://support.netapp.com:443
