NetApp Knowledge Base
StorageGRID does not report alert when network port is brought down manually
452
Visibility:
Votes:
0
Category:
storagegrid-webscale
Specialty:
sgrid
Last Updated:
Applies to
NetApp StorageGRID 11.4 and above
Issue
When a network port is manually brought down using ifconfig command, StorageGRID does not report the Storage appliance link down on network port alert
  • root@AMS-SG5712-8T-4:/var/local/log # ifconfig hic2
hic2: flags=6211<up,broadcast,running,slave,multicast> mtu 1500
ether 00:a0:98:d5:46:7c txqueuelen 1000 (Ethernet)
RX packets 5 bytes 1016 (1016.0 B)
RX errors 0 dropped 87 overruns 0 frame 0
TX packets 2 bytes 256 (256.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 120 memory 0x386000680000-3860006fffff
  • root@AMS-SG5712-8T-4:/var/local/log # ifconfig hic2 down
hic2: flags=6146<broadcast,slave,multicast> mtu 1500
RX packets 130 bytes 18022 (17.5 KiB)
RX errors 0 dropped 95 overruns 0 frame 0
TX packets 8 bytes 1024 (1024.0 B)
New to NetApp?
