NetApp Knowledge Base
StorageGRID audit.log is not rotated and /var/local/audit/export/ is full
987
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
StorageGRID 11.4
Issue
  • audit.log is not rotated
  • Use% of /var/local/audit/export/ is 100%
Command: df -h
Result:
Filesystem      Size  Used Avail Use% Mounted on
/dev/sdc        200G  200G   28K 100% /var/local/audit/export
  • manage-audit.log shows Unhandled error
 INFO -- clean: starting, with mode "clean" and PID <PID>
 INFO -- clean: attempting to lock audit management
 INFO -- clean: beginning audit log management session (mode clean, pid <PID>)
ERROR -- clean: Unhandled error. Unable to manage audit logs.
ERROR -- clean: Active log /var/local/audit/export/audit.log must be a file (Bycast::Logs::Directory::FileArgumentError)
ERROR -- clean:     /usr/local/sbin/manage_audit_logs.rb:159:in `initialize'
ERROR -- clean:     /usr/local/sbin/manage_audit_logs.rb:632:in `new'
ERROR -- clean:     /usr/local/sbin/manage_audit_logs.rb:632:in `initialize'
ERROR -- clean: Exiting...
New to NetApp?
