NetApp Knowledge Base
StorageGRID alert Storage appliance storage connectivity degraded after replacement
234
Visibility:
Votes:
0
Category:
storagegrid-webscale
Specialty:
sgrid
Last Updated:
Applies to
  • NetApp StorageGRID
  • NetApp SG6000 appliance
Issue
  • StorageGRID UI reports Storage appliance storage connectivity degraded following a HBA or Compute node replacement.
  • All port on E-Series backend are UP with no incrementing fibre channel errors in state-capture-data.txt > fcDump
  • All ports on Compute node HBA are reporting UP in /var/local/log/kern.log:
    • localhost kernel: [12.00] lpfc 0000:b0:00.0: 0:1303 Link Up Event x1 received Data: x1 x0 x80 x0 x0 x0 0
      localhost kernel: [13.00] lpfc 0000:b0:00.1: 1:1303 Link Up Event x1 received Data: x1 x0 x80 x0 x0 x0 0
      localhost kernel: [14.00] lpfc 0000:b0:00.2: 2:1303 Link Up Event x1 received Data: x1 x0 x80 x0 x0 x0 0
      localhost kernel: [15.00] lpfc 0000:b0:00.3: 3:1303 Link Up Event x1 received Data: x1 x0 x80 x0 x0 x0 0
  • In StorageGRID base-os-logs/command_results.txt is missing paths:
    • command `multipath -ll` completed with code 0. Output:
      StorageGRID-obj-00 (xxxxxxxx) dm-3 NETAPP,INF-01-00
      size=22T features='3 queue_if_no_path pg_init_retries 50' hwhandler='1 alua' wp=rw
      |-+- policy='service-time 0' prio=50 status=active
      | |- 17:0:0:222 sdak 66:64 active ready running
      | `- 18:0:0:222 sdbs 68:96 active ready running
      `-+- policy='service-time 0' prio=10 status=enabled
      `- 15:0:0:222 sdc 8:32 active ready running
  • storage-array-profile in E-Series ASUP report Unassociated Host Ports:
  • STORAGE ARRAY
    Default type:              Factory Default
    Host Port:                 10:00:00:00:00:00:00:d7
    Default Host Cluster
    Host:                      StorageGRID Appliance
    Host type:                 Linux DM-MP (Kernel 3.10 or later)
    Interface type:            Fibre Channel
    Host port identifier:      10:00:00:00:00:00:00:d9
    Alias:                     0x
    Host port identifier:      10:00:00:00:00:00:00:da
    Alias:                     0x
    Host port identifier:      10:00:00:00:00:00:00:d8
    Alias:                     0x
New to NetApp?
