NetApp Knowledge Base
StorageGRID VM emulated hardware clock can run too slow/fast
78
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
  • StorageGRID
  • Virtual Machines
Issue
Every now and then a VM triggers the Alert:
Local clock large time offset
The offset between local clock and Network Time Protocol (NTP) time is too large.
When checking the actual time, everything seems ok.
There is no offset between time from date command and NTP server or other GRID nodes.
Rebooting the node resolves the alert temporarily.
New to NetApp?
