NetApp Knowledge Base
StorageGRID SNMP traps does not contain the source GRID name when alerts are generic
96
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
  • StorageGRID 11.6.0.7
  • SNMP Traps
  • Multi StorageGRID environment
Issue
  • SNMP traps generated by the StorageGRID for generic alarms such as below do not contain the host field of the trap as the alarms are for the entire StorageGRID system and not for specific nodes.
    • Expiration of load balancer endpoint certificate
    • Expiration of global server certificate for S3 and Swift API
    • Many more
  • To determine which StorageGRID sent the trap, the only reference point left is the source IP which needs to be converted to hostname manually to identify the admin node name/source StorageGRID.
  • There is no existing functionality that sends the source StorageGRID name along with each trap.
New to NetApp?
