NetApp Knowledge Base
StorageGRID Low Root Disk Capacity - Due to a running process
59
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
NetApp StorageGRID
Issue
StorageGRID reports LowRootDiskCapacity indicating the space available for root filesystem data is low.
Initial Troubleshooting/validation
  1. Login to the Primary Admin node via SSH
  2. Run df -h
  3. Verify the usage under the / filesystem
  4. Monitor this alert to see if the issue resolves on its own and the disk space becomes available again.
New to NetApp?
