StorageGRID Admin Node reports LowRootDiskCapacity due to full root directory
Applies to
- NetApp StorageGRID
- Secondary Admin Node
- SG1000 appliance
Issue
- StorageGRID UI reports
Low Root Disk Capacitywith Disk space available: 0 bytes / Total disk space: 20.96 GB on Non-primary Admin Node - Additional alert
nginx-gw service using backup configurationpresent on the same node.
df -houtput on the affected node records:Filesystem Size Used Avail Use% Mounted onoverlay 20G 20G 0 100% /tmpfs 64M 8.0K 64M 1% /devshm 64M 4.1M 60M 7% /dev/shm/dev/mapper/decrypted-StorageGRID-SG-OS-part1 20G 20G 0 100% /configtmpfs 512M 3.4M 509M 1% /tmptmpfs 19G 104K 19G 1% /run/dev/mapper/decrypted-StorageGRID-SG-OS-part2 180G 4.9G 176G 3% /var/localtmpfs 93G 0 93G 0% /proc/acpitmpfs 93G 0 93G 0% /sys/firmwaretmpfs 5.0M 0 5.0M 0% /run/lock/dev/sdc 462G 3.3G 459G 1% /var/local/audit/export/dev/sdd 200G 7.0G 193G 4% /var/local/mysql_ibdatatmpfs 64M 0 64M 0% /var/local/nginx/spooltmpfs 64M 0 64M 0% /var/local/nginx-gw/spool
