High StorageGRID Node network reception frame error count persists after replacement
Applies to
NetApp StorageGRID Appliances
Issue
- Receiving periodic alerts for :
- The alert triggers on the same interface
- Frame error counts are high
hic2: flags=6211<UP,BROADCAST,RUNNING,SLAVE,MULTICAST> mtu 1500ether xx:xx:xx:xx:xx:xx txqueuelen 1000 (Ethernet)RX packets 153837280268 bytes 181640324309688 (165.2 TiB)RX errors 0 dropped 0 overruns 0 frame 106823733TX packets 128831196937 bytes 143972668070514 (130.9 TiB)TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0device interrupt 158 memory 0x386000680000-3860006fffff
- The alert may self-resolve within minutes but reoccurs.
- SFP and fiber cable replacements on both the node and switch sides do not prevent recurrence.
- MTU and FEC settings have been verified as correct and consistent across the network.
