HIC3 reports DOWN with legacy alarm active after upgrading to StorageGRID 11.9
Applies to
- NetApp StorageGRID 11.9
- StorageGRID Appliances
Issue
- Following an upgrade to StorageGRID 11.9, a legacy alarm reports DOWN for HIC3 on storage node(s).
- Following a node reboot running StorageGRID 11.9, HIC3 may also reports as DOWN.
- StorageGRID UI may report alert:
Storage appliance storage connectivity degraded ifconfigoutput on affected node(s) show HIC3 is assigned the same IP address as the GRID network (eth0).
root@Node:~ # ifconfig -v hic3
hic3: flags=4098<BROADCAST,MULTICAST> mtu 1500
inet 10.0.xx.xx netmask 255.255.255.0 broadcast 0.0.0.0
ether 10:70:fd:38:7a:ca txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
root@Node:~ # ifconfig eth0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::xxx:xxx:xxx:9f9e prefixlen 64 scopeid 0x20<link>
ether 10:70:fd:35:9f:9e txqueuelen 1000 (Ethernet)
RX packets 1199219716 bytes 739291479680 (688.5 GiB)
TX packets 1208337183 bytes 348717393971 (324.7 GiB)
