NetApp Knowledge Base
vCenter task for SCV restore job gets stuck at 80% due to name resolution issue
114
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Plug-in for VMware vSphere (SCV) 6.0
  • DNS A record for the IP address of the cluster management LIF was recently changed
Issue
  • NetApp Restore task for SCV restore job in Recent Tasks pane of vSphere Client gets stuck at 80%
  • The cancel icon of the task is grayed out
  • vmcontrol_<JOB_ID>.log shows error:
ERROR <SCVHOST> --- [558021762-86974] c.n.a.r.AbstractRestoreStrategy          : [JobId:<JOB_ID>] Restore failed with exception: Single File Snapshot Restore Failed:  Failed to get the resource from the resource pool.
 Object reference not set to an instance of an object.
.  Failed to get the resource from the resource pool.
  • ProtectionService-<YYYYMMDD>.log shows error:
[ERR] [Storage] [TID:257] [RID:0HNC5AQFUCGBT:00000003] [CID:] [JID:0] Failed to run a command NetApp.DataProtection.Storage.CommandAPI.ConnectNcController, Exception:System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (00000005, 0xFFFDFFFF): Name or service not known
   at System.Net.Dns.GetHostEntryOrAddressesCore(String hostName, Boolean justAddresses, AddressFamily addressFamily, ValueStopwatch stopwatch)
   at System.Net.Dns.GetHostAddresses(String hostNameOrAddress, AddressFamily family)
   at NetApp.Ontapi.NaServer..ctor(String name, String uri, Int32 port)
   at NetApp.DataProtection.Storage.CommandAPI.ConnectNcController.Connect(String name)
   at SnapDrive.Nsf.Core.Storage.StorageConnection.InitializeONTAP(SDStorageSystemId storageSystemId)
[INF] [Storage] [TID:257] [RID:0HNC5AQFUCGBT:00000003] [CID:] [JID:0] End GetSALStorageConnectionRetry
[DBG] [Storage] [TID:257] [RID:0HNC5AQFUCGBT:00000003] [CID:] [JID:0] GetResource exception in initializor : Name or service not known
[INF] [Storage] [TID:257] [RID:0HNC5AQFUCGBT:00000003] [CID:] [JID:0] Begin GetSALStorageConnectionRetry
[INF] [Storage] [TID:257] [RID:0HNC5AQFUCGBT:00000003] [CID:] [JID:0] End InitializeONTAP
[DBG] [Storage] [TID:257] [RID:0HNC5AQFUCGBT:00000003] [CID:] [JID:0] InitializeONTAP() throw exception: Failed to connect to storage system. Please check the connectivity between host and storage system.
[DBG] [Storage] [TID:257] [RID:0HNC5AQFUCGBT:00000003] [CID:] [JID:0] GetResource exception in initializor : Failed to connect to storage system. Please check the connectivity between host and storage system. . Name or service not known
[INF] [Storage] [TID:257] [RID:0HNC5AQFUCGBT:00000003] [CID:] [JID:0] End GetStorageConnection
[DBG] [Storage] [TID:257] [RID:0HNC5AQFUCGBT:00000003] [CID:] [JID:0] InitializeONTAP() ex.InnerException: Name or service not known
[INF] [Storage] [TID:257] [RID:0HNC5AQFUCGBT:00000003] [CID:] [JID:0] UpdateResult - Single File Snapshot Restore Failed:  Failed to get the resource from the resource pool.
New to NetApp?
