NetApp Knowledge Base
Which versions of (SAP) Sybase ASE are supported by the SnapCenter Creator Plug-in for Sybase 1.0 ?
451
Visibility:
Votes:
1
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter 4.x
  • SnapCenter Creator (SCC) Plug-in for Sybase 1.0
  • Sybase ASE 15.0
  • SAP Sybase ASE 16.0
Answer
Listed versions of Sybase ASE (2) are fully supported by the Sybase ASE Plug-in 1.0 from the Automation store (1)
Additional Information
Notes:
  1. due to the split between SnapCenter software and the NetApp supported Automation Store plug-ins, the Sybase ASE version compatibility cannot be determined from the Interoperability Matrix (IMT)
  2. the product changed names from "Sybase ASE" to "SAP Sybase ASE"going from version 15.0 to 16.0 due to the buy-out of Sybase by SAP.
