Which SCV settings need to be updated when the domain name is changed?
Applies to
- SnapCenter Plug-in for VMware vSphere (SCV)
- Changing the domain name due to organizational changes or other reasons
Answer
Check the following and update if necessary:
- If vCenter server is specified by FQDN, modify the vCenter
- If search domain is specified, modify the network settings
- If NTP server is specified by FQDN, modify date and time
- If storage systems are added by FQDN, remove storage, then add storage again
- If domain users are added in Run As Credentials for VM guest file restores, configure credentials for VM guest file restores
- If SMTP server is specified by FQDN, modify Email settings from Settings in the left navigator pane of the SCV plug-in
Additional Information
additionalInformation_text
