NetApp Knowledge Base
What is the minimum set of privileges that SC Plug-In for PostgresSQL users require
14
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • NetApp SnapCenter Plug-in for PostgreSQL
  • Linux and Windows hosts running PostgreSQL protected by SnapCenter
Answer
  • The SnapCenter Plug-in for PostgreSQL requires a PostgreSQL database user account with sufficient privileges to perform the required backup, restore, and management operations
    • The minimum privileges required for the database user is assigned from the database perspective and can be found in the PostgresSQL documentation
  • SnapCenter supports RBAC at the application level. You can assign permissions so only certain users or groups (e.g., DBAs) can view, update, or use the credentials for backup and restore operations.
Additional Information
additionalInformation_text
