Upgrade to SCSQL 6.x fails with PowerShell or .NET error
Applies to
- SnapCenter Plug-in for Microsoft SQL Server (SCSQL) 6.0 or 6.0.1
- Upgrade from 5.x
- PowerShell (PS)
- ASP.NET Core Runtime Hosting Bundle
Issue
- Host upgrade from 5.x to 6.0 or 6.0.1 fails with an error in the
<installation_path>\NetApp\SnapCenter\App_Data\log\SnapManagerWeb_<id>.log:
ERROR SnapManagerWeb_746190 PID=[12040] TID=[110] The required PowerShell version 7.4.2 is not available on <Host_FQDN> Install or upgrade the PowerShell to 7.4.2 and restart the host.
- May also see the following error in the SnapCenter_Windows_host_Plug-in_install_<job_id>.log:
SWInstallerHelper.CheckForRollbackLogs: SETUP_ERROR: Failed Plugin: SnapCenter Plug-in for Microsoft SQL ServerSWInstallerHelper.CheckForRollbackLogs: SETUP_ERROR: MSI Error code: 1603SWInstallerHelper.CheckForRollbackLogs: SETUP_ERROR: ErrorMessage:
- SC RunAs account used to execute the upgrade is part of the local admins group on the host(s).
