NetApp Knowledge Base
Snapcenter Host cannot be deleted because it is already being removed
375
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Server (SC)
  • SnapCenter Plug-in for VMware vSphere (SCV)
  • SnapCenter MySQL NSM database
Issue
  • When trying to Remove-SmHost via PS C:\Windows\system32>  Remove-Smhost -HostNames <HostName> -F
Are you sure you want to remove the host and its resources.?
[Y] Yes  [A] Yes to All  [N] No  [L] No to All  [S] Suspend  [?] Help (default is "Y"): Y
Name : Remove Host '<HostName>'
StartTime           : 2/20/2025 11:57:06 AM
EndTime :
IsCancellable       : False
IsRestartable       : False
IsCompleted         : False
IsVisible           : True
IsScheduled  : False
PercentageCompleted : 0
Description         :
Status              : Queued
Owner               :
Error :
Priority            : None
Tasks               : {}
ParentJobID         : 0
EventId             : 0
JobTypeId           : 10
ApisJobKey          :
ObjectId            : 0
PluginCode          : NONE
PluginName          : NONE
HostId              : 0
RoleId              :
JobIds              : {}
ScsJobId            :
Message in SnapCenter GUI :  Host <HostName> cannot be deleted because it is already being removed.
  • When in Confirm Fingerprint config for Host Name - Fingerprint - Validation you will see :
Authenticity of the host cannot be determined. as well as:
There is no match for your search or data is not available.
On top of this message the error message:
Failed to connect to the host <HostName>. Verify connectivity to the host.
New to NetApp?
