NetApp Knowledge Base
SnapCenter or SCV returns API Invoke failed when adding SVM with HTTPS Protocol
185
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter [SC]
  • SnapCenter Plug-in for VMware [SCV]
  • Storage Virtual Machine [SVM]
  • Secure Sockets Layer [SSL]
Issue
  • Can't add the storage host using port 443/HTTPS, but 80/HTTP may work.
  • After removing SVM from the Storage Systems menu, adding them back fails with API Invoke Failed
  • Node hosting the LIF for the SVM doesn't allow https://node_mgmt_IP/SPI and a ERR_CONNECTION_CLOSED is logged in the browser.
  • Discovery or Backup  job fails with:
2025-04-09T15:12:18.4391491-04:00 Verbose SAL PID=[4744] TID=[6992] ZAPI flag enable ..
2025-04-09T15:12:18.4391491-04:00 Verbose SAL PID=[4744] TID=[6992] UserName: vsadmin
2025-04-09T15:12:18.4391491-04:00 Verbose SAL PID=[4744] TID=[6992] Invoking Connect-NcController ...
2025-04-09T15:12:18.4547833-04:00 Critical SAL PID=[4744] TID=[6992] The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: API invoke failed. at System.Management.Automation.Runspaces.PipelineBase.Invoke(IEnumerable input)
at SnapDrive.Nsf.Core.Storage.StorageConnection.InitializeONTAP(SDStorageSystemId storageSystemId)
2025-04-09T15:12:18.4547833-04:00 Verbose SAL PID=[4744] TID=[6992] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: API invoke failed.
New to NetApp?
