SnapCenter for SAP HANA plugin 4.9 fails to be properly installed
Applies to
- NetApp SnapCenter for SAP HANA 4.9 plugin
- Microsoft Windows 2022
- OpenJDK 11
Issue
When installing the SAP HANA plugin 4.9, the installation does not properly complete and the following error is provided:
YYYY-MM-DDThh:mm:ss+01:00 INFO SnapManagerWeb_50 PID=[XXXX] TID=[XXX] Is required Java version found : False
YYYY-MM-DDThh:mm:ss+01:00 ERROR SnapManagerWeb_50 PID=[XXXX] TID=[XXX] ErrorCode (-1), ErrorMessage (The required Java version is not found on hostname.example.com. Install 64-bit Java version 1.8 or higher.)
