SnapCenter backup, verification or clone jobs fail with error "Specified Vserver not found"
Applies to
- SnapCenter Server (SC) 6.0, 6.0.1, 6.1
- SnapCenter Plug-in for Microsoft SQL Server (SCSQL) 6.0, 6.0.1, 6.1
- SnapCenter Plug-in for Microsoft Exchange Server (SCE) 6.0, 6.0.1, 6.1
- ONTAP 9.14.1 and higher
- NetApp ONTAPI (ZAPI)
- Backups, clone or verification jobs
Issue
- SC backup or clone / verification jobs fail with error:
<installation_path>\Program Files\NetApp\SnapCenter\SMCore\log\SMCore_<id>.log:
DEBUG SMCore_102 PID=[7940] TID=[27] REST Mode: Invoke-NcCli. cmd = volume clone create
DEBUG SMCore_102 PID=[7940] TID=[27] Invoking Invoke-NcCli command
DEBUG SMCore_102 PID=[7940] TID=[27] Command: Invoke-NcCli. Storage System: <SVM>. Version: NetApp Release 9.14.1P5: Sat May 18 19:42:16 UTC 2024. Connection Mode: REST
DEBUG SMCore_102 PID=[7940] TID=[27] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: [400]: Specified Vserver not found- On SC 6.0 it can fail indicating
Specified Vserver not foundin case ZAPI was disabled or ONTAP version is between 9.13.1 and 9.15 :
DEBUG SMCore_433327 PID=[1320] TID=[183] ZAPI Mode: Invoke-NcCli. cmd = volume clone create
DEBUG SMCore_433327 PID=[1320] TID=[183] Invoking Invoke-NcCli command
DEBUG SMCore_433327 PID=[1320] TID=[183] Command: Invoke-NcCli. Storage System: <SVM> Version: NetApp Release 9.14.1P7: Thu Aug 01 03:07:44 UTC 2024. Connection Mode: ZAPI. Username: <user>. Storage added as VSERVER_DIRECT.
2024-09-02T02:31:48.6446746+02:00 DEBUG SMCore_433327 PID=[1320] TID=[183] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: [400]: Specified Vserver not found- Error seen in
AUDIT-MLOG-TXT.GZlog in ONTAP ASUP:
Error: Specified Vserver not found
