NetApp Knowledge Base
SnapCenter SQL log backup retention fails with "Remove Snapshot failed on volume"
203
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Server (SC) 5.0P2 and earlier
  • SnapCenter Plug-in for Microsoft SQL Server (SCSQL) 5.0P2 and earlier
Issue
SnapCenter SQL log backup retention fails with error:
Retention : Error: Remove Snapshot '<Snapshot_Name>' failed on volume '<Volume_Name>'.
Error: Remove Snapshot '<Snapshot_Name>' failed on volume '<Volume_Name>'. The executed command was terminated because the setting variable "ErrorActionPreference" or a general parameter is set to "Stop": This Snapshot copy is currently used as a reference Snapshot copy by one or more SnapMirror relationships. Deleting the Snapshot copy can cause future SnapMirror operations to fail.
New to NetApp?
