SnapCenter PostgreSQL restore fails when restore command is not configured
Applies to
- SnapCenter 6.x with Plug-in for PostgreSQL (SCC)
- Linux plug-in host
- ONTAP 9.x (NFS or SAN)
Issue
- Attempting to restore a PostgreSQL database using SnapCenter fails within seconds. The restore job aborts at the Pre Restore Application step and no data files are modified.
- The following error appears in the SnapCenter restore job log and in the PostgreSQL plug-in log (
PostgreSQL_<jobID>.log):
SCC-00154: Pre restore handling of plug-in [PostgreSQL] failed with error [Restore command is not set for <instance_name>, set it to continue recovery.] exit code [-1]
