SnapCenter Plug-in for Oracle backup fails with discovery failed for object failed to retrieve unit serial number
Applies to
- SnapCenter Plug-in for Oracle
Issue
SnapCenter Plug-in for Oracle backup fails with error
Failed on 'hostname': Activity 'Discovering File-System' failed with error: Discovery failed for object <directory> with error Failed to retrieve the unit serial number for the device '/dev/..', Reason: 'SCSI inquiry failed. Check if the disk.EnableUUID parameter is set to TRUE in the VM configuration file.'
