SnapCenter Oracle Application Plugin Intermittent Backup Failures with CG Commit Timeout Errors
Applies to
- SnapCenter Server
- SnapCenter Plug-in for Oracle (ORASCPM)
- SnapCenter Custom Plugins
Issue
SnapCenter Oracle Application backups intermittently fail with the following error seen in the ORASCPM job log:
Creating consistency group Snapshot copy [...] failed with error [CG commit failed for SVM:<svm_name>, reason: Failed to save the consistency group. Error: Connection timed out]The SMCore job log shows:
cg-start Done on SVM: <SVM NAME>ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: API invoke failed:The SSL connection could not be established, see inner exception.
